Coilover question posted by WhiTTe Z on November 05, 2011 at 10:52 AM
Our suspension is not adjustable, so you need to change out the upper camber arms with adjustable ones. For the front, you can use the 300degree camber shim kit for a cheaper solution.
I went with the PowerTrix setup on everything (including tension rod) except for the Front Upper Camber Arm where I used the 300degree shim kit.
